Mechanical Keyboard light problem (?)
carlhistorillo
Okay so, my Redragon Anala Mechanical Keyboard's "X" light is kinda dim compared to other keys. I have no experience on soldering whatsoever btw
Have you tried to just remove the key and clean it, both the key and keyboard were it sits?
Normally LED's either work or don't work.
If you need to replace the LED, you will need to find someone with good soldering skills as they are not very big.
If they keyboard still is under warranty you can have it replaced as that would be considered a manufacturer defect. I do not recommend trying to solder it yourself. You could get someone else to however it would cost you more to hire a professional than what that keyboard is worth.
