"Media Disconnected" problem
Eric Kithaka
11
I am unable to connect to a router. It's a zhone znid-gpon-2424a. I tried logging in using the user manual, but it did not work out. I hit the CLI, and this is what I got:
C:\WINDOWS\system32>ipconfig
Windows IP Configuration
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Ethernet adapter Ethernet:
Link-local IPv6 Address . . . . . : fe80::d041:a33d:4836:dea2%11
Autoconfiguration IPv4 Address. . : 169.254.222.162
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Wireless LAN adapter Wi-Fi:
Link-local IPv6 Address . . . . . : fe80::e00e:85e6:5a9f:4430%6
IPv4 Address. . . . . . . . . . . : 192.168.88.20
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.88.1
Tunnel adapter Local Area Connection* 3:
Tunnel adapter isatap.{7FCF8682-E14D-41F7-B273-BDB460365830}:
Tunnel adapter isatap.{30D51DE7-0D0C-4216-A926-935CBCA2A226}:
I would like to know how to go about dealing with this 'MEDIA DISCONNECTED' problem because it is making it impossible for me to even log into the router. I know that the problem is not my pc or the ethernet cable I am using because I also use another router with the same pc and cable and they work just fine. Please help
Media disconnected would most likely be a bad cable, cable plug, or port. Anything along the physical path between the pc and router.
Can you open your pc and ensure that the network adapters are all fully seated? Check all cables and connections. Swap out ethernet cables with known working cables.
Another thought is the error message itself. Could be misleading - i.e., the network adapter cannot find the router (looking for the wrong IP) and just announces "Media disconnected" as a catch-all error.
Try a factory reset on the router to ensure the router is at 192.168.0.1.
Wondering about that Default Gateway IP of 192.168.88.1?
Could be a IP typo or some other misconfiguration involved.
What is your DHCP server IP?
Default seems to be 192.168.0.1
(Reference: http://m.setuprouter.com/router/zhone/znid-gpon-2426-uk/login.htm)
Who has admin rights to the router?
Be sure that when connecting wirelessly that any wired adapters and other wireless adapters (if any) are disabled).
If you do not have IPv6 service via your ISP then uncheck using IPv6.
The [Default Gateway IP of 192.168.88.1] was assigned by another network that my pc was connected to at that time. I have the admin rights to the router. But they are completely useless if I cannot even log into the router. To log in to a router, you need it's IP address, which I cannot get because every time I try to get the CLI to tell me the IP address of the router, I get the MEDIA DISCONNECTED' line
Also that link that you provided was the first place I looked, it was not very helpful.
This is my network configuration outlook when my pc is not connected to any other network:
C:\WINDOWS\system32>ipconfig /all
Host Name . . . . . . . . . . . . : DESKTOP-R8R98Q7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : A0-1D-48-E1-35-EC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 56-35-30-AF-9C-2F
Description . . . . . . . . . . . : Realtek RTL8188EE 802.11 b/g/n Wi-Fi Adapter
Physical Address. . . . . . . . . : 54-35-30-AF-9C-2F
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
