Hello,
I recently decided to purchase a 20" widescreen monitor to replace the TV that I was using. I also had to purchase a DVI-VGA adapter as my video card did not have a VGA input (6870HD).
Having plugged in the new monitor and then set the resolution to the maximum (1600x900), this is the result I am getting...
The desktop does not clearly fit. The Monitor OSD information tab states that is is running at 1280x960 and not the 1600x900 that I set within Windows.
I don't know what I can do to fix this, can anyone help?
Thanks in advance.
Thanks in advance.
