Medium/ high specs and extremly low performace, WHY?
Hi; I just bought a brand new acer laptop (with the following specs: NVIDIA Geforce GTX 1050 Ti, 4GB,Intel core i5 8300H,8Gb , 1Tb HDD... ) and when I try to start a game I have extremly low performance! Also I updated my drivers to latest version, I set my NVIDIA as default for games, and the max temperatures are normal. I noticed when I start the game, uses 100% of my CPU ! Why is that and how can I resolve it ?? Please help. Thanks.
1| make sure you're on the latest BIOS update.
2| Uninstall and reinstall your GPU drivers with the latest found off Nvidia's support site.
3| What games are you trying to play and at what settings?
Is that the metrics when you're taxing any game? You may want to see what your idle system resource usage is. I'd suggest you perform a repair install.
