Meeting 1600MHz and 2400MHz RAMs on a 1600MHz motherboard
Best bet w/ those is to try the 2x8GB setand set up for 1600 at 9-9-9-24 1.5 and see how they do, should prob run fine, then add the 2x4GB set and might need to raise DRAM voltage to 1.55 for the 4 sticks and mixed amounts (2x8GB in slots 1-3 from CPU, 2x4 in 2-4) this will keep the DRAM at 12GB in each channel and dual channel enabled
Don't all plugged rams adapt to the slowest one?
