I'm sure this is a very common problem here on the forums, but I really need help. My computer seems to run fine from the inside, but the screen stays in power save mode and I get that shiny red light. I tried like 10 different sticks that are compatible but nothing worked. The board is used from ebay but It looks great and claimed to work 100% and tested. Is there anything I should try doing before going towards the seller aggressively?
MOBO: p8z68-v pro/gen3
Main ram: 2x4 ddr3 1600mhz corsair vengeance
