Question Memory clock is stuck at 6000MHz ?
Aug 7, 2022
I had my 1650 Super for a while and the memory clock would change depending on what i would be doing but recently its been at 6000MHz for a while even when im not doing anything. I am using 2 monitors.
maybe your power management mode for your gpu is on prefer maximum performance go to the nvidia control panel and manage 3d settings then find power management mode then set it to optimal and click apply try that
Set it to optimal power, check that image scaling is turned off and restart pc. If you are gaming, you need to use the nvidia control panel to change settings back and forth.
