Memory Compatibility Help
ksefan18
Will these components work together? G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2400 Memory with the Intel Core i5-4690K 3.5GHz Quad-Core Processor and Asus Maximus VI Hero ATX LGA1150 Motherboard. Will I have to overclock anything?
Yes, it will work fine. The memory if in case runs @1600MHz instead of the rated speed then you will have to change it to 2400MHz in the BIOS. That is the only change that is required.
