when I have 4 RAM modules installed in my pc, I get the 55 Q-code on my motherboard indicating that there is no memory installed. I also get this with 2 sticks, however with one stick it actually works. whith one stick installed, I get different Q-codes related to the CPU. I cannot read all of them before the disappear, but it usually hangs around 13(pre-memory CPU initialization started), 32 and 35(both CPU post memory initialization). the rest is a buch of Q-codes I cannot read before they disappear. also, when I turn the PC on, it keeps on shutting off after about ten seconds, only to restart again after one or two seconds. it does not give any signal to my monitor. I have tried hooking it up to both the motherboard as well as my graphics card, both not giving any signals. I used different cables, including ones I knew for sure worked, but no luck. it keeps shutting off after about ten seconds, then restarting again, and repeating.
specs:
motherboard: ASUS ROG maximus VIII ranger
processor: Intel core i5 6600K
RAM: 32(4X8)GB RAM
PSU: corsair GM 750M
graphics card: GTX 980
does anyone know what could cause this and how to solve the problem?
I should note that the processor power plug is not compatible with the power cord on my PSU, so instead I am using an adapter that converts one PCI-e cord into the correct power cord. this does not seem to be the problem, however.
thanks in advance for the help,
Chris
specs:
RAM: 32(4X8)GB RAM
Chris
