I have A Friend with a asus sabertooth x58, I want t know memory suggestions and why dual channel memory is impossible or bad.
I also need memory recommendations for my new build.. which would you choose for sandy bridge.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461
as for my friend I guess his x58 can't use gkill dual channel memory such as the types on this page.
http://www.newegg.com/Store/Category.aspx?Category=17&name=Memory
if not what would you recommend from triple channel? what can he use? and what is his limit amount?
I hear x58 is 24gb so I guess he can only reach 12 gb as in tri channel config or maybe even 8 gb if it is possible.
I am looking at gkill and corsair memory if you guys could give advice.
