I've heard that Pentium 4 processors work best with two clips of memory at a certain bus (do you know which it is?), so I thought "Great, I'll just buy my memory according to that bus!", but no...
My motherboard, Asus P4T, declares that it's "Max System Bus" is set to 100 Mhz, does that mean that you only can use PC100 memories? Can you use memories at all with 300 Mhz bus?
I also read here at this site that RDRAM is the preferred sort of memory for P4 CPU's, what if I had one old PC100 64 MB clip of memory and a brand-new RDRAM clip of 128 MB @ 300 MHz plugged in at the same time?
As you understand from these questions, I am a bit of a newbie on this area. It would be really nice if someone would cover the entire subject. I'm having a problem over here.
/ Topaz
/ Topaz
