Hello, basically I am getting daily bsod with memory management BSOD. I have tried running windows memory diagnostic tool and there is no errors. I have also tried a fresh install of windows 10, bios reset making sure the xmp profile is disabled. When I get the bsod I often get 2 or 3 more bsod one after the other on restart. Eventually the pc will boot and I can game use it as normal. Sometimes when I get multiple bsod of death I do get system thread handle exception (dxgkrnl.sys & nvlddmkm.sys) I believe these are gpu related, I have used ddu to uninstall nvidia drivers and done a fresh install of the latest nvidia drivers but it still happens. The memory bsod gives the below error in the dmp file -
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
the PTE. Parameters 3/4 contain the low/high parts of the PTE.
CPu is not overclocked (Not possible) Gpu is overclocked and applied on startup.
Specs-
i7 8700
2x8gb ddr4 corsair vengeance lmp 3000 runs at 2666 on my motherboard
Gigabyte 1080
Gigabyte b360m d3h-cf
any help would be much appreciated!!
Specs-
i7 8700
Gigabyte 1080
