Question memory not running at 3200mhz
Jun 1, 2020
7
ok im newish to the pc world but i have 4 8gig sticks 3200mhz of team tforce rgb.when i set the bios to 3200 it goes in to a boot loop i can only boot if i set the ram to 2400mhz.from what cpuz says it is only running at 1198mhz ive updated the bios but cant seem to figure out how to get it to run higher any help would be great asus strix b450-f
ryzen 7 2700x
32gig 3200mhz team teforce rgb
rtx 2070 super
evga 650watt ps
Jun 1, 2020
7
DMAN999
Ambassador
why would it make a differnce about the 2 differnt kits? its the same ram just got it at 2 differnt times
Because even though the kits may have the same model number that does NOT mean the are the exact same RAM kits.
The ICs and/or silicon can be different from one kit to the other.
That is why RAM is sold in kits , to ensure that they are the same and will work together at their Rated speeds.
