My motherboard is an ASRock X99 Extreme4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157543
It says it supports DDR4 3000+(OC) / 2933+(OC) / 2800(OC) / 2400(OC) / 2133 / 1866 / 1600 / 1333 / 1066 memory standards.
So I purchased some Corsair DDR4-2400 memory -
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233887
The problem I'm having is when I have all 4 DIMM's installed the computer will blue screen within the first 10-15 minutes of operation. After that it will run fine the rest of the day. If I remove two of the DIMM's then I have no issues at all. I have also swapped the DIMM's to make sure it was not bad memory sticks.
I'm not sure what is wrong but it got me thinking. Now I'm no expert but I assume the 'oc' means overclock so am I supposed to overclock something in order for my computer to run stable with my ram? Could it be a bad motherboard ?
