Ok guys os here is my problem. I just bought an Asus motherboard with some Ocz black edition ram for the Amd be cpus. Anyways the memory that I bought is not listed as compatible in my motherboard manual. However the board has an option called Memok which is where you press a button on the board and it sets the voltages on the ram to comply with the motherboard standards. I can get it to boot when I use the Memok option. I save the settings in Bios and then turn off my pc. However I have my board outside of the case so I have to unplug the board to turn it off right now. However when i do that and try to reboot the settings are not saved and I have to use the Memok option again. So do the Bios go to default after i unplug the system for awhile?? I just want to know ho to save these setting permenantly. Thanks all
