Question memory running higher speed than set on MB
IceMyth
567
97
Hi,
I have the below MB, where I bought the below memory kit for it (Later on will upgrade to 3900X/X570). The memory is running at 33xx speed which I think higher than what it says on the MB specs (except I see 3200(OC)+). So my question, is it safe to keep this speed or I should lower it?
Note: I am using XMP profile (1), whereas Profile (2) sets it to run at 3600Mhz but BSOD.
Note: The DRAM is set to use 1.27 volt (Under volt from 1.36)
MB: https://www.msi.com/Motherboard/X370-GAMING-PRO-CARBON.html
MEM: https://www.newegg.ca/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232822?Item=N82E16820232822
Thanks,
Ice
