Memory Running SLow
Matt_336
6
I have 16.0GB Dual-Channel Unknown @ 2300MHz (16-15-15-35)
And for some reason It says it is running at 1063MHz I have the XMP enabled so im not sure why its doing this.
You could take out the 8gb stick yes,that with XMP enabed should make the rest work at their rated speed.
For adding voltage, again yes->to the Vram. Don't go over 1.35V.
Can/will you do the next so i know what parts used?
download hwinfo32,
install and open it=click run,
close the top window which is the system summary,
at the left top click "save report",
at the bottom of the next window check "short text report",
after that you'll see what's in the pc,
copy by clicking "copy to clipboard" and rightclick+paste in your next respons
Computer: MSI MS-7971
CPU: Intel Core i5-6400 (Skylake-S, R0)
2700 MHz (27.00x100.0) @ 1995 MHz (20.00x99.8)
Motherboard: MSI B150 PC MATE (MS-7971)
Chipset: Intel B150 (Skylake PCH-H)
Memory: 16384 MBytes @ 1064 MHz, 16-15-15-35
- 4096 MB PC19200 DDR4 SDRAM - A-DATA Technology DDR4 2400 2OZ
- 8192 MB PC19200 DDR4 SDRAM - Apacer Technology 78.CAGN8.AF30B
Graphics: GIGABYTE GeForce GTX 960 IX OC
NVIDIA GeForce GTX 960, 2048 MB GDDR5 SDRAM
Drive: ADATA SP600, 125.0 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: WDC WD10EZEX-00WN4A0, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: Crucial_CT525MX300SSD1, 512.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: HL-DT-ST DVDRAM GH24NSC0, DVD+R DL
Sound: Intel Skylake PCH-H - High Definition Audio Controller
Sound: NVIDIA GM206 - High Definition Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
OS: Microsoft Windows 10 Home (x64) Build 14393.1066 (RS1)
Since ddr ram do you need to double the speed which makes it run at 2126mhz. Still lower than it should be able to,but you mixed ram which can give issues and maybe this is the most stable the bios can make it work.
Maybe with some extra voltage those modues will run 2400mhz.The above is a weird nr though,is the bclk set at 100?
Also,look what the current voltage is on which the ram is running.Can be found in the bios/uefi as well.
yeah thats what I am seeing and I should add more voltage to the memory or take out the 8gb stick maybe?
