M maksimenko.kost.ua Prominent Sep 18, 2018 26 0 530 Nov 17, 2018 #1 I've heard that Ryzen CPUs need some really fast memory, but how fast exactly? 2400/2666/3000? I have a tight budget, and the price difference are quite something here locally.
Solution A A aswindamara Nov 17, 2018 you only need 2400mhz, since ryzen give an option to budget builder to maximize performance with overclock. mine is 3000Mhz CL 16, from 2400Mhz Cl 14.
A aswindamara Upstanding Mar 16, 2018 168 0 210 Nov 17, 2018 Solution #2 you only need 2400mhz, since ryzen give an option to budget builder to maximize performance with overclock. mine is 3000Mhz CL 16, from 2400Mhz Cl 14. Upvote 0 Downvote Solution
CountMike Titan Oct 31, 2015 35,669 3,835 147,990 Nov 21, 2018 #3 Which Ryzen ? For 2200g and 2400g without dedicated GPU it's essential to use faster RAM, for the rest not so much. Upvote 0 Downvote
M maksimenko.kost.ua Prominent Sep 18, 2018 26 0 530 Nov 21, 2018 #4 CountMike : Which Ryzen ? For 2200g and 2400g without dedicated GPU it's essential to use faster RAM, for the rest not so much. 5 1600. I guess I'll find something 2400-2666 Upvote 0 Downvote
