memory speed problem with msi b450m pro vdh ryzen 3 2200g
Jan 31, 2019
22
so i have a ryzen 3 2200g msi b450m pro vdh and ddr4 3200mhz gskill ripjaws memory 2x4gb and in the bios it said that my ram was 2133 mhz which is simply not the case when i try gaetting my ram to 3200 (i did put in custom timings that micro center said were correct) and my pc booted however as i was checking cpuz to see if it worked i got a blue screen to restart the pc and then had to reset the bios everyone tells me to enable xmp however my the bios says that xmp isnt supported however the product page says otherwise pls help (i know this is a run on sentence im only in middle school)
My parents won’t let me sell the ram sticks I got so can someone pls come up with a solution that doesn’t involve hardware changes I’m fine with running at 3000 MHz or 2666 MHz or anything in between thanks
