Hi, I just bought some ram (1066mhz, http://www.overclockers.co.uk/showproduct.php?prodid=MY-093-CR) and installed onto my new P5k. On the first setup, it was still running at 400mhz (looking at cpu-z, under memory) so I went into the bios and changed it to 1066mhz instead of auto. Then it 533/534.3/.4 mhz (its changing slightly all the time) but it still says PC2-6400 (400 mhz) under SPD under max bandwidth. I also wanted to know if the ram is running at 2.2 volts, I cant change it in the bios, it dosent show the jumperfree configuration settings for some reason........thanks
