Hi All,
I own gigabyte ga-ma785gmt-ud2h mobo / AMD Athlon II X4 620 processor 2.60 GHz with Transcend 2GB DDR3 1333 DIMM CL9 memory stick.
Now i would like to upgrade it to 10GB to run vmware images.
I am planning to purchase it from Flipkart. Please suggest what are the key things i need to consider while upgrading.
should i go for corsair or transcend ?
should i buy 1*8GB or go for pairs 2*4GB ? (4 slots available)
will my existing single 2GB effective after upgrade when it goes to 10GB ?
If i go for corsair with my existing Transcend, will it create issue ?
shall i consider the below models :
Corsair Vengeance DDR3 4 GB: Rs.2200
http://www.flipkart.com/corsair-vengeance-ddr3-4-gb-1-x-gb-pc-dram-cmz4gx3m1a1600c9/p/itmd2rypbx4eehaf?
pid=RAMD2RYPMVWCEK6E&al=e6Lg5RXJ0IcBjTKBPzbDe8ldugMWZuE7%2BW7da8XnwKRazFWl7Kjqq%2F5Lc%2Fu3kKutgIqH20wD2W8%3D&ref=L%3A8497259924632584576&srno=b_1
Transcend DDR3-1333 DDR3 4 GB:
http://www.flipkart.com/transcend-ddr3-1333-ddr3-4-gb-pc-dram-jm1333kln-4g/p/itmd2rypzczsv8e7?pid=RAMD2RYPSWYFFUSM&al=e6Lg5RXJ0Id1O%2FoAK
%2FbaEcldugMWZuE7%2BW7da8XnwKSBdwhN54Yv2O2nroB1DYQapp60VwN9xrk%3D&ref=L%3A-8373612751913269651&srno=b_1
Corsair Vengeance DDR3 8 GB:
http://www.flipkart.com/corsair-vengeance-ddr3-8-gb-1-x-gb-pc-dram-cmz8gx3m1a1600c10/p/itmd8cfmbufg3dnq?
pid=RAMD8CFMX53FYAXY&icmpid=reco_pp_same_desktopcomponent_ram_1&ppid=RAMD2RYPMVWCEK6E
Transcend JetRam DDR3 8 GB: Rs.3560
http://www.flipkart.com/transcend-jetram-ddr3-8-gb-pc-dram-jm1333klh-8g/p/itmdfzhzhnfzzhae?
pid=RAMDFZHXGXTEHVJS&al=e6Lg5RXJ0IdTOmc72HG4K8ldugMWZuE7%2BW7da8XnwKSM1FHWRqIIEn3KZd4ie6%2BNlycvW%2BMfm7A%3D&ref=L%3A5786842144066652249&srno=b_1
Please suggest.
Regards
Jedy
Please suggest.
Regards
Jedy
