Greetings,
I bought a high-end PC about 3 years ago but I feel that at the moment its 2GB RAM and the fact that it runs Windows 7 32bit holds me back.
I would like to upgrade to 8GB so I wont have any issues in the future as well as try out Windows 7 64bit. It's the first time I attempt to upgrade my system so please bear with me.
Problem is that I currently use (2x1GB) OCZ dual channel that are discontinued, which in fact is really dissapointing since Im really pleased with OCZ's platinum non-low voltage series ( http://www.newegg.com/Product/Product.aspx?Item=20-227-244&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=1#scrollFullInfo )
In addition, I use a decent Core 2 Duo CPU ( http://ark.intel.com/products/33911/Intel-Core2-Duo-Processor-E8500-%286M-Cache-3_16-GHz-1333-MHz-FSB%29 ) and a Nvidia Geforce GTX 285 GPU.
Lastly, my motherboard is ASUS P5Q3 ( not the Deluxe version, however I dont think they differ a lot ) with an Intel® P45 chipset. ( http://www.asus.com/Motherboards/Intel_Socket_775/P5Q3/#specifications ). I would like to mention that reading through the QVL list found at the website most models are discontinued here in local stores ( I live in Athens ) and that the Corsair 8GB (4x2GB) dual-channel kits that are highly-reccomended by Corsair for my motherboard seem to be problematic on some boards after I looked them up on the web. ( http://www.corsair.com/cmx8gx3m4b1333c9.html/ or http://www.corsair.com/dominator-with-dhx-pro-connector-8gb-dual-channel-ddr3-memory-kit-cmp8gx3m4a1333c9.html/ ).
Looking forward to your suggestions,
Xionas
Xionas
