Question Memory won't work. System doesn't boot. I get ez debug led on Ram and CPu.
Feb 13, 2020
Hi I ran into following issue. My Pc was working fine but after newest BIOS update it worked kinda buggy. Sound was stuttering, windows were maximizing and minimizing.
Now it won't boot at all.
I got EZ debug leds on RAM and CPU.
motherboard: B350 tomahawk
memory:HyperX 2x8gb 3200mhz (amd optimized) w.e
cpu: Ryzen 7 1700
I have HyperX 2666mhz 1x8GB and it works and it boots normally.
I tried Cmos clear, tried going back to previous BIOS ver, tried every slot, tried 1 stick at the time - nothing.
Does someone have a suggestion?!
Many thanks for reply
lynx1021
816
93
5,140
45
The Bios you updated to was probably for the Ryzen 3000 series and some Bios chips are not big enough to hold the 1st gen and 3d gen .EDIT I thought it was a B450 , Disregard
What was the previous BIOS ? What do you have now? Do you have windows 10?
Yes I have Win10 pro.
Motherboard is B350 tomahawk
current BIOS is American Megatrends Inc. 1.MO 1/23/2019.
As for the previous version it was default I think the Bios that came with motherboard
