Memory_management and IRQL not less or equal
M477h3w
Commendable
Feb 22, 2016
30
Greeting intellectuals,
I have been getting these errors / BSOD increasingly often on my Razer Blade 14 - MEMORY_MANAGEMENT and IRQL_NOT_LESS_OR_EQUAL. It seems like these are memory related issues, so I don't know what to do. It occurs randomly, but it seems it might be in correlation to the amount of Chrome tabs I have open.
As a side note, I also have to reinstall Realtek drivers every month or so, as my microphone starts doing weird stuff otherwise.
Any ideas of where I can look for possible fixes? Should I just reset windows?
Most likely a hardware problem. Resetting Windows will be a waste of time. Pull your RAM, put a little Deoxit Gold on the contacts and reinstall. If that doesn't fix it, try installing just one RAM card, then the other to figure out which one is bad and then replace.
Unfortunately I don't think I can remove the RAM on my Razer Blade, as it is soldered on. I also can't RMA because I'm in South Africa.
