My Build
B350 Tomahawk Arctic
XFX RAW 2 5700xt
AMD RYZEN 5 3600
Vengeance 16gb DDR4
So I keep getting this issue even though I just reset the pc and installed a new version of windows, I downloaded Whocrashed and this is what I keep getting
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Sat 4/11/2020 2:49:59 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\041120-6718-01.dmp
This was probably caused by the following module: hardware.sys (hardware)
Bugcheck code: 0x1A (0x41792, 0xFFFFEB01026A16C8, 0x8000000000000, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred. A corrupted PTE has been detected.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hardware.sys .
Google query: hardware.sys MEMORY_MANAGEMENT
And its saying that this is a driver issue... but I just reset my pc, so my other thought was maybe it was the ram, so I ran the memory diagnostics test and nothing, is it possible that my ram is faulty but windows just wasn't able to catch it? Or is the Hardware.sys connected to something that I've downloaded?
XFX RAW 2 5700xt
AMD RYZEN 5 3600
Vengeance 16gb DDR4
C:\Windows
C:\Windows\Minidump
