Merging partitions, need help
rohver
74
So I installed Windows on a new SSD. I used to run the OS from a regular 1 TB hard drive with two partitions, one for the OS, a 250 gig one.
Now that I have a new primary, can anyone tell me how to merge the partition on the HDD without deleting any of my data? My disk manager image for reference : http://imgur.com/IYabi0a (Disk 2 is my SSD)
While we are here, any way I can change the disk order?
p.s. I would like to merge the partitions without installing additional software if possible. If it cannot be avoided, are there any free ones?
you converted the partitions to dynamic volumes.
It is logical, so underneath there are still two partitions with all limitations.
but i guess you wanted them to appear as a single partition in File Explorer for convenience
