Question Meshify C case (how many fans and which)
Lukhino
162
6
4,585
Hello,
i have this setup
3xArctic P12 PMW Front intake
1x CPU Coller Noctua NH-D14
  • 1x NF-P14 PWM premium fan
  • 1x NF-P12 PWM premium fan
2xExhaust Fractal GP-12
http://ibb.co/hym1Nnq
http://imgway.cz/s/8T49
I use 3x Arctic P12PMW in front to max 1000RPM
-But i think i dont need these fan, these fans are good mount as radiator right?
-Do you prefer, 2x140mm or 3x120mm? And what brand do you use to push more air, without buzzing... I prefer quiet setup.
-Meshify C case has some dust filter in the front. I tried Arctic P14PMW fans but i sell it, I heard these fans more than 3x120mm in probably same setup.
Have i change stock fan to another brand? (2xFractal GP12 - exhaust)
Thank you for help.
2 CPU cooler fans.
5 case fans.
Are you currently unhappy with temperatures?
Are you currently unhappy with noise levels?
I'm not sure what your complaints are or why you want to change anything.
Have you done any experimentation with what you have now?
2 CPU cooler fans.
5 case fans.
Are you currently unhappy with temperatures? - is ok
Are you currently unhappy with noise levels? - yep, i want to quiter setup wuth good performance
Have you done any experimentation with what you have now? - Yep i changed 3x120 Arctic PMW to 2x140 Arctic PMW, but i sell it, because these setup was louder tahn 3x120, in the same PMW curve.
