Question Meshify C fans..Do I need more than stock?
Barty1884
"Need", no.
Probably beneficial though, depending on the hardware you have installed.
The stock fans are fine - but adding a third 120mm fan (2x 120mm intake at the front, 1x 120mm exhaust at the back) would be a good idea - and won't break the bank either.
mazinyo
71
"Need", no.
I agree. wont break the bank. so which one would you recommend? this is my build
CPUAMD Ryzen 5 2600X Processor Box (Gen 2)1
MotherboardsGigabyte B450M DS3H1
RAM MemoryDDR 4 16G (8GX2) 3000 CL16 1.35V Vulcan Yellow Team1
CasesFractal Design Meshify C Blackout 1
Power SuppliesCorsair CX550 550W PSU 80+ Bronze1
Solid State Drives (SSD)Intel® SSD 660p 512GB M.2 PCIe 80mm1
Video CardsPalit Geforce GTX1660Ti STORMX 6G GDDR6 192bit DVI HDMI DP
Barty1884
2x140mm in front would be a good choice too.
Pure Wings are decent enough fans.
With the blackout edition, you don't have to worry much about the aesthetic look - so even adding 2x 120mm in front would be fine (for 3x in, 1x exhaust). Top exhaust is an option too - but with 4 fans, you can play about with the layout and see which performs best. I wouldn't expect much variance though... 3x120mm front intake, 1x 120mm rear exhaust is probably the best setup there.
mazinyo
71
140mm is the same price as 120mm, so for the same price i would rather take the 140mm. If I put 2X140mm in front, I will have a spare stock fan, so I thought about putting it Top exhaust
