Accidentally installed GRUB to the MBR and couldn't boot into windows, was given the ol' 0xc000000e. Attempts to fix it from a windows 10 installation disk's command prompt were unsuccessful as certain commands didn't work.
Since then I have installed windows on a separate drive and am wondering if I can fix the MBR on the broken drive from Windows on a different drive.
If you need any more info then tell me,
