Messed up OS booting after failed installation of W7 using W8.1 on the other drive
Mike Rook
19
Hello,
to quickly get an idea of what is going on, please see this:
https://neosmart.net/wiki/winload-efi-missing-corrupt/
However, my problem is a bit more complicated. I use two OS on my PC - W7 and W8.1. I needed to make a clean install of W7, so I did it like I always do (at least I think so). I downloaded W7 iso from mircrosoft page using my key, wiped the drive, made new patition, then used daemon tools to boot the iso file and install the system. However, the installation failed and left me with the problem you can see above.
I have already installed the W7 on the other drive succesfully using flash drive boot converted from the iso file. But while booting the drive where W8.1 is, I still get the W7 boot error screen. So, the computer thinks, there should be W7 on the drive. How do I explain to the system there is no such system and it should just boot W8.1 normally without attempting to boot winload.efi? If you understand it well, you can see there is no reason in trying to repair W8.1, because this OS has no issues at all, it is the trace left somewhere on the drive after the failed installation.
I have already wiped temp files issued on the date of the accident - no change. It is not a system breaking error, but it makes me a bit upset to see this screen each time I launch the computer.
Thank you for your tips, guys! :)
You need to go back to the beginning and start all over again.
Create a DVD or USB bootable, not daemon from the other drive.
Disconnect ALL drives except for the one you want the OS on.
Install, deleting ALL existing partitions on that drive.
Or, you could mess about with EasyBCD and attempt to "fix it".
Personally, I'd just start over.
MERGED QUESTION
Question from Mike Rook : "Cleaning W8.1 after failing to install W7 on another drive using W8.1 drive"
Thank you very much! :)
I treid the EasyBCD - there were 2 boot entries and one of them was installation boot set as primary. I just deleted it using the program and the issue is gone.
You made me happy, man.
