This is going to be a little long. I have a new computer with a SSD and normal HDD. It came with windows 7 installed on the SSD. Motherboard is a gigabyte Z68AP-D3, BIOS version F7b. I decided (and yes, I now regret it) to reinstall windows on the HDD and use the SSD as a cache using Intel's smart response technology. All seemed ok (As part of this I had to change the "PCH SATA Control mode to RAID(XHD)" from its original IDE setting). Windows 7 installed, I installed the motherboard drivers, and then the graphics card drivers. When I tried to restart following the graphics card drivers I got "Disk boot failure Insert system disk and press enter".
I have played a lot and reinstalled windows a number of times. At the moment windows will start if I change the PCH SATA control mode from RAID(XHD) to IDE but I cant install the gigabyte utility to set up acceleration because I've not got a RAID set up and windows doesn't see the SSD although it is present and working in device manager.
If I leave the SATA control mode in RAID (XHD) windows won't start, the standard CMOS BIOS page can't see any discs but the advanced BIOS features page will allow me to set the order of disks to boot from, ie it can see and correctly identify the HDD and SSD.
I think I have totally messed up the Raid settings using the Intel RST utility (Ctrl-I) at post. Both disks are seen as non-RAID and I can't recreate a RAID0(Cache) volume.
Also just to confuse things more there is probably an installation of Windows 7 sitting on the SSD.
If anyone can help I would be very grateful.
