Mhmmm Graphics card help.
Wilson20114
18
I installed this graphics,
http://www.amazon.co.uk/gp/product/B00HYFIZU6?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
And after installation, Continious beeps were happeneding (short beeps)
After that, It stopped beeping, and i was able to see image through the VGA that was already on my PC, I cannot connect my monitor to the graphics card (i can, but no image will show up, just a black screen) Help?
Specs------> http://i.imgur.com/FvvZ2SI.png
PSU ---------->Model No. FSP450-60EMON
AC INPUT:230-250V-,5A,50-60Hz
DC OUTPUT 450W.
Two possibilities:
1) You may not have connected the 6-pin PCI-E power cable from the PSU to the R7 260 card.
2) The 450w PSU may not be powerful enough either in wattage, or in the amperage on the 12v rail. Others can advise you on that better than I can. I'm no PSU guru, far from from it, though I do know that the FSP brand is highly thought of as a quality brand.
its connected properly, Also, the PSU should be well enough.
What is your build exactly? Are you sure the GPU is connected securely as well?
Have yu checked the original post? It tells you everything.
