As I'm still looking around to find the RAM following this spreadsheet: https://drive.google.com/file/d/0B5ePJLHhrAUMZFBnc05TLUZMYzg/view
It seems impossible to find the yellow colored ratio ones, as they are always out of stock.
eg:
- DDR4 2133 with CL 12
- DDR4 2400 with CL 12
- DDR4 2666 with CL 13
- DDR4 2800, 2933 & 3000 with CL14
- DDR4 3200 with CL 15
- DDR4 3333 and 3400 with CL 16
Those mentioned above seems to be impossible to come across unless you want to wait weeks, if not months. (very limited in my country)
My question is: does it really matter much the ratio between CL and Frequency is? Can't I just buy any DDR4 of 2666Mhz without concerning about the CL? Will I notice a difference?
I am planning to overclock the CPU from 4.0 Ghz to 4.6Ghz using the 5-way optimization software provided by ASUS with their new motherboard the Z170 series. Not sure if this would OC my RAM automatically aswel.
Cheers
eg:
Cheers
