Mic doesn't work when both slots of sound card is used
sam_farhan94
Commendable
Aug 16, 2017
105
So I'm using this USB sound card at the moment: https://www.lazada.com.my/products/kotion-each-s2-external-usb-sound-card-plug-and-play-stereo-headset-adapter-for-pc-laptops-ps4-i239009812-s313540931.html?spm=a2o4k.searchlist.list.21.19c26a9bO12wra&search=1
There are 2 sound jacks and 1 mic jack. The mic doesn't work when the second jack is used. So whenever I want to use my mic I need to unplug one of the sound jacks that are being used and only use one, only on the first port. Is it just a problem with the sound card or is there a way to enable my mic while the second jack port is being used?
MERGED QUESTION
Question from sam_farhan94 : "Mic doesn't work when the second sound jack port is being used"
So I'm using this USB sound card at the moment: https://www.lazada.com.my/products/kotion-each-s2-exter...
