[SOLVED] Mic recording playback problem
LuckyXIIIGaming
26
So when I use OBS, or Audacity, or Vegas to do voice overlay it sounds almost like im Underwater but much clearer and the audio has a swishy sound almost that sounds like my voice is going from left to right slightly its strangely odd. I've been looking all over the webs about it and its not the same problem from what I am finding.
Currently use Nady SCM 800 mic, ties into a power amp then goes into USB.
Software I use Voicemeter which is for simple soundboard bass and treble.
I've tested my mic and such without the Voicemeter, but I have no other soundboards to run into my computer to test.
Also sometimes I listen to playback of friends who have streamed and my mic on their end doesnt sound the same as it does on my pc to me.
Okay, so in VoiceMeter I was tweaking with the settings a bit and set most things to 192Khz and set some other settings to 1024 and Higher and it seemed to clear the problem up so must have been software related.
