micro atx + 8800gtx = lanbox or similar? help please!
golddeath
Im looking for any mini itx or micro atx case that can hold a 8800gtx and a athlon 64x2 6000+ processor. other parts such as a psu and mobo would be helpful as well. thanks
jaffa
63
golddeath,
My friend and i were hunting around for suitable cases for this exact same scenario and came across this case from Silverstone. http://www.silverstonetek.com/products/p_contents.php?pno=sg03
In real terms to give you a rough idea of the size, the case is not much taller than his Creative 5.1 subwoofer and narrower! I was somewhat impressed, i even considered changing my Antec 900 for it, but then i'd miss the air-con for my room!
Silverstone actually recommend suitable PSU's on the website, however most standard 150 x 160 x 85mm ATX PSU's will fit. I would recommend one with short power leads, perhaps modular too as cable management within this case can be a little tricky.
The case will fit a standard micro-atx motherboard, as an example this one from gigabyte:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2775
I am not saying that is the best mb to go for, it's just to give you an indication of size, and the spec you can get on such a board.
The rest of the components you're pretty much free to pick yourself depending on budget and so on.
Jaffa
Onus
The Apevia X-Qpack2 can fit those things, but I cannot recommend it because of quality issues (and of course you wouldn't use its included PSU). It's a wonderful design, but poorly executed. I mention it only because you may want to look at its layout for comparison.
For any micro-ATX case, a modular PSU is a very good idea. The X-QPACK2 design can take a full-sized one; I used a Mushkin modular which is actually a little deeper than standard but still fit.
G
Guest
Guest
Cheap and Cheerfull:
http://www.ebuyer.com/product/146272
20 quid, as usual problem always finding a case that will support a full sized atx psu because lets face it micro atx psu's are just lame and don't provide the 650w + juice you need for the modern set up.
here is the case layout and dimensions:
http://www.casecom.com.tw/structure/MAstructure.jpg
A typical psu dimensions and a blu ray drive (you do the math :p):
http://www.driverheaven.net/reviews.php?reviewid=568
http://www.liteonit.eu/optical-storage-blu-ray-internal-bd-rom/dh-4o1s/specification.html
and last but not least the dimension of a 280gtx
http://www.xfxforce.com/en-us/products/graphiccards/200series/280GTX.aspx
measure it all up and you have a cheap NORMAL looking case as oppose to these hideous cube things with see thru plastic on the sides, that case I suggested can even house a 120mm fan which is a must for cooling and I'll even reccomend a fan to put there:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-001-NC&groupid=701&catid=57&subcat=4
Trust me these fans are SILENT, so there you have a nice super quiet pc that you don't want to throw a brick at when you walk into the room.
Similar threads
