Micro ATX Cube Build
CV_Taihou
649
So I'm looking to switch form factors in the next little while and threw this build together as something that would a)perform well, b)look good, and c) be able to utilize a good chunk of existing parts that I have in my current rig (hence some of the odd choices.
Is everything compatible? PCPartpicker wasn't letting me choose the ASUS Strix R9 390X for whatever reason despite it being able to fit according to Corsairs website. Is this an error on their part, or am I imagining things that it would fit. Wouldn't want to buy everything only to discover that it's not compatible.
Here's what I've got for a build so far
i5-6600k Micro-ATX
I like the Node. Would have recommended it, but I was away from the computer for quite awhile yesterday. I did see the note about some bays might be impacted, which a builder like you can figure out. Sure beats getting the PCPARTPICKER red letter warning that basically says "Warning Will Robinson, Danger, Danger..." Or is that reference showing my age?
Looks like a solid build to me. Have fun with it!
At this point I'm really hoping I can swing something with a similar look at least since I don't want to replace the card.
It's available. Not too sure on the price though. 255CAD Shipped seems like an awful lot for a case. Are the LED's built in to the other one? If they aren't it might not be too bad
Found a couple other options that could work, as the only real requirement I have is that I want the case to have a window.
Phanteks Enthoo EVOLV ITX
NZXT Manta Mini ITX
Thermaltake Core X1 Mini ITX
