Micro ATX / Mini ITX Mobo for i5 2500k @ 4.5Ghz
kyanite
46
Hi everyone.
I need a Micro ATX or Mini ITX motherboard for my OC'd @ 4.5Ghz i5 2500k.
Any recommendations?
I've spotted a few but I don't think most of them could handle such a significant overclock.
Thanks
Will the GIGABYTE one work with my 2500k? As it says 1150 socket and the 2500k is 1155?
As for the second ASRock one, a quick google search has people complaining saying that overclocking on it isn't possible.
Oh. My Mistake. Correction on that one.
That would be Gigabyte GA-Z77-HD4 ATX LGA1155 Motherboard
https://pcpartpicker.com/part/gigabyte-motherboard-gaz77hd4
But that's ATX... I specifically asked for MITX/MATX.
That one looks really good. Just a shame it doesn't seem to be in stock anywhere as it has been discontinued.
How does this compare? Particularly with regards to overclocking, as I really want to keep my 2500k running at 4.5Ghz in a smaller case.
http://www.amazon.co.uk/dp/B008DYLWUW/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B007RS71O6&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=0NW5RHJQPQC1BKFYQJC0
or this one?
http://www.amazon.co.uk/dp/B007OCJWTM/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B007P710G4&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=0ZR8K8DQNNH9WYQXDWRT
Whats the difference between Z77 & H77?
I think I'm going to buy the Z77M, as Z mobos are more suited to overclocking and besides that, both boards are almost identical.
Thanks for your help.
