Micro Atx psu with 8 pin power connector?
jd1211
Commendable
Feb 16, 2016
13
im currently working on putting together my second computer and will be using the micro-ATX MSI B150m MORTAR Motherboard which requires an 8 pin ATX power connector. I dont need a PSU with more than 300w but all of the ones i see don't seem to come with this 8 pin connector. Can anyone recommend a PSU for a Cooler Master n200 m-ATX case that comes with an 8 pin power connector on top of the 24pin? Or perhaps i wasn't looking hard enough?
Power Supply: XFX XT 400W 80+ Bronze Certified ATX Power Supply ($45.98 @ Newegg)
Total: $45.98
Generated by PCPartPicker 2016-03-19 12:48 EDT-0400
Connectors
Motherboard cable (20+4 pin): 1, 1x sleeved (20+4)pin (50cm)
CPU cable (4+4 pin/8 pin): 1, 1x Fixed Flat cable (4+4)pin (55cm)
PCI-E 6+2 Pin (GPU): 2, 1x Fixed Flat cable (6+2)pin+(6+2)pin (55+10cm)
SATA: 3, 1x Fixed Flat Cable (45+15+15cm)
Peripheral connector (Molex/HDD): 2, 1x Fixed Flat cable (40+10cm)
Floopy Power : +1 Floopy (10cm)
Cable Shielding: 20+4 Sleeved, others...
Total: $45.98
Connectors
Cable Shielding: 20+4 Sleeved, others flat cable
