[SOLVED] Micro ATX vs small ATX case
Sep 30, 2019
4
I am planing on building a SFF ryzen build for LAN parties\air travel. I am torn between a cooler master Q500L or Q300P . I need to have a carry handle and will be using X570 motherboards 1 or 2 front RGB fans so I will need to go all the way down to mini ITX if I get the micro ATX case . I would also like some semblance of durability. Thank you for any help I get.
A side window could cause you issues, durability wise. Glass and acrylic can easily be broken, so I would recommend against it. This would be easily portable.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($194.79 @ OutletPC)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard ($219.99 @ Amazon)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3733 Memory ($89.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($99.99 @ Adorama)
Video Card: Zotac GeForce RTX 2060 SUPER 8 GB MINI Video Card ($399.89 @ OutletPC)
Case: Fractal Design Node 202 HTPC Case ($67.99 @...
Case: Fractal Design Node 202 HTPC Case ($67.99 @ Amazon)
Power Supply: EVGA SuperNOVA GM 550 W 80+ Gold Certified Fully Modular SFX Power Supply ($89.94 @ ModMyMods)
Total: $1162.58
Generated by PCPartPicker 2019-10-01 09:32 EDT-0400
