Micro-Stuttering Problems in Games
triplesatvat
15
Friends,
I have put a lot of effort into a crazy rig for gaming. It's like super ultra high, but about a 10,000 score + passmark rig. Gtx 980, 4gb vram, i7-2600 4 core, 16gb 1600 ram, intel 900 series SSD.
I have a 50mbps connection with Time Warner.
Here is the challenge I face: in many games I play, i get "micro-stuttering", where the game plays fine and says I"m getting 60fps all the time (vsynced), but every 20-25 seconds, there are little hiccups in the gameplay.
I have tried all kinds of things..windowed mode, checking drivers, repairing the game, turning off vsync, turning off max frame rates...nothing has worked
The games where I have had the greatest annoyance are some of my Blizzard favorites, Diablo 3 and Starcraft 2, and some new games like vanishing of ethan carter
I run at 2560x1600 on a Dell Monitor and do not use DSR. Please help! Below I will post my tracert info.
I play in the Americas for SC2. . Here is my tracert for 12.129.202.154:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 37 ms 35 ms 15 ms cable-mac1.nadmma01-ar4002.nyroc.rr.com [67.252.32.1]
3 16 ms 15 ms 15 ms gig4-31.nadmma01-rtr001.alb.northeast.rr.com [24.29.44.73]
4 14 ms 18 ms 18 ms rdc-74-76-241-142.alb.northeast.rr.com [74.76.241.142]
5 27 ms 26 ms 31 ms rdc-74-76-241-193.alb.northeast.rr.com [74.76.241.193]
6 31 ms 28 ms 31 ms ae-5-0.cr0.nyc30.tbone.rr.com [66.109.6.74]
7 23 ms 27 ms 24 ms 107.14.17.216
8 41 ms 27 ms 25 ms 209.220.18.33.ptr.us.xo.net [209.220.18.33]
9 59 ms 33 ms 25 ms 207.88.13.58.ptr.us.xo.net [207.88.13.58]
10 26 ms 24 ms 26 ms 207.88.14.178.ptr.us.xo.net [207.88.14.178]
11 42 ms 30 ms 31 ms 206.111.13.246.ptr.us.xo.net [206.111.13.246]
12 98 ms 99 ms 98 ms cr1.n54ny.ip.att.net [12.122.131.94]
13 99 ms 93 ms 98 ms cr2.cgcil.ip.att.net [12.122.1.2]
14 119 ms 94 ms 94 ms cr1.cgcil.ip.att.net [12.122.2.53]
15 98 ms 100 ms 98 ms cr2.dvmco.ip.att.net [12.122.31.85]
16 98 ms 99 ms 98 ms cr1.slkut.ip.att.net [12.122.30.25]
17 98 ms 99 ms 118 ms cr2.la2ca.ip.att.net [12.122.30.30]
18 435 ms 92 ms 121 ms gar5.lsrca.ip.att.net [12.122.85.33]
19 101 ms 95 ms 95 ms 12.122.251.186
20 91 ms 94 ms 106 ms mdf001c7613r0004-gig-12-1.lax1.attens.net [12.129.193.246]
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Here is my tracert for the other Americas IP, 63.240.104.93:
1 2 ms <1 ms 2 ms 192.168.0.1
2 62 ms 25 ms 30 ms cable-mac1.nadmma01-ar4002.nyroc.rr.com [67.252.32.1]
3 21 ms 12 ms 12 ms gig4-31.nadmma01-rtr001.alb.northeast.rr.com [24.29.44.73]
4 15 ms 15 ms 17 ms rdc-74-76-241-142.alb.northeast.rr.com [74.76.241.142]
5 28 ms 32 ms 54 ms rdc-74-76-241-193.alb.northeast.rr.com [74.76.241.193]
6 28 ms 31 ms 26 ms be26.cr0.nyc30.tbone.rr.com [107.14.19.26]
7 28 ms 25 ms 30 ms 107.14.17.216
8 25 ms 24 ms 24 ms 209.220.18.33.ptr.us.xo.net [209.220.18.33]
9 31 ms 30 ms 27 ms 207.88.13.58.ptr.us.xo.net [207.88.13.58]
10 26 ms 24 ms 43 ms 207.88.14.178.ptr.us.xo.net [207.88.14.178]
11 29 ms 29 ms 51 ms 206.111.13.246.ptr.us.xo.net [206.111.13.246]
12 29 ms 50 ms 32 ms cr1.n54ny.ip.att.net [12.122.131.94]
13 26 ms 29 ms 55 ms gar1.nw2nj.ip.att.net [12.122.131.81]
14 26 ms 24 ms 27 ms 12-122-254-210.attens.net [12.122.254.210]
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
Here is my tracert for diablo 3:
Tracing route to 12.129.209.68 over a maximum of 30 hops
2 32 ms 29 ms 30 ms cable-mac1.nadmma01-ar4002.nyroc.rr.com [67.252.32.1]
3 39 ms 17 ms 13 ms gig4-31.nadmma01-rtr001.alb.northeast.rr.com [24.29.44.73]
4 18 ms 55 ms 28 ms rdc-74-76-241-142.alb.northeast.rr.com [74.76.241.142]
5 28 ms 51 ms 30 ms rdc-74-76-241-193.alb.northeast.rr.com [74.76.241.193]
6 30 ms 31 ms 29 ms ae-5-0.cr0.nyc30.tbone.rr.com [66.109.6.74]
7 * 21 ms 27 ms 107.14.17.216
8 36 ms 26 ms 27 ms 209.220.18.33.ptr.us.xo.net [209.220.18.33]
9 30 ms 30 ms 33 ms 207.88.13.58.ptr.us.xo.net [207.88.13.58]
10 26 ms 28 ms 28 ms 207.88.14.178.ptr.us.xo.net [207.88.14.178]
11 30 ms 27 ms 31 ms 206.111.13.246.ptr.us.xo.net [206.111.13.246]
12 98 ms 99 ms 100 ms cr1.n54ny.ip.att.net [12.122.131.94]
13 99 ms 98 ms 103 ms cr2.cgcil.ip.att.net [12.122.1.2]
14 98 ms 98 ms 99 ms cr1.cgcil.ip.att.net [12.122.2.53]
15 100 ms 96 ms 99 ms cr2.dvmco.ip.att.net [12.122.31.85]
16 100 ms 96 ms 102 ms cr1.slkut.ip.att.net [12.122.30.25]
17 99 ms 98 ms 99 ms cr2.la2ca.ip.att.net [12.122.30.30]
18 94 ms 104 ms 94 ms gar5.lsrca.ip.att.net [12.122.85.33]
19 96 ms 97 ms 92 ms 12-122-254-230.attens.net [12.122.254.230]
20 95 ms 94 ms 126 ms mdf001c7613r0003-gig-10-1.lax1.attens.net [12.129.193.242]
21 95 ms 94 ms 96 ms 12.129.248.118
22 116 ms 88 ms 112 ms 12.129.209.68
I'd advise you first remove this huge amount of data and just the stuff that you yourself wrote. The answer to your problem isn't going to be inside of it anywhere, and a lot of people will see that and just click off cause they don't want to read it, so you will get a lot more help by removing it.
On to your problem, have you checked the temperature of your system? If its getting too hot it could be having issues. Also how long ago did you install your OS? It could be graphics driver clashing from whatever GPU you had in it before, or old programs. If you have an extra hard drive, I would say doing a test install of the OS, drivers, and the game and see if you still see the issue happening, or if not you might consider just reinstalling Windows right off.
Hi - I did a full driver uninstall and reinstall and that still didn't fix things. In starcraft, for example, it still says i'm getting 2 network spikes per minute and it's very laggy. This is super weird since I have a 50mbps connection. And it's not constantly laggy, it's these little mini-spikes. I don't know where it's the system or the internet connection, but I've had this problem with diablo 3 / sc2 for a long time now
And no temperature problems - my cpu rests at 35 c and is max 60 c under full load of ultra settings and 2560x1600. For same settings, video card at rest is about 25-30c with 60-70c under maximum load
Did you use a program like CCleaner to make sure all parts of the old driver software were removed?
Those temps aren't bad so I'd say its probably not those. It still could be a software issue. Have you tested the games in offline mode to see if it still happens?
