Here are my specs:
url=https://pcpartpicker.com/list/fJ2bNN]PCPartPicker part list[/url] / Price breakdown by merchant
CPU: Intel - Core i5-6600K 3.5GHz Quad-Core Processor (Purchased For $209.99)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (Purchased For $36.99)
Motherboard: Asus - Z170-E ATX LGA1151 Motherboard (Purchased For $114.99)
Memory: Kingston - FURY 8GB (2 x 4GB) DDR4-2400 Memory (Purchased For $32.99)
Memory: Kingston - FURY 8GB (2 x 4GB) DDR4-2400 Memory (Purchased For $72.02)
Storage: SanDisk - SSD PLUS 120GB 2.5" Solid State Drive ($59.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (Purchased For $66.99)
Video Card: Gigabyte - GeForce GTX 970 4GB G1 Gaming Video Card (Purchased For $120.00)
Case: NZXT - H440 (White/Black) ATX Mid Tower Case (Purchased For $70.00)
Power Supply: EVGA - SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply (Purchased For $77.55)
Monitor: Acer - XB240H ABPR 24.0" 1920x1080 144Hz Monitor (Purchased For $160.00)
Keyboard: Corsair - STRAFE Wired Gaming Keyboard (Purchased For $79.99)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse (Purchased For $79.99)
Headphones: Logitech - G633 Artemis Spectrum 7.1 Channel Headset (Purchased For $69.99)
Speakers: Logitech - Z313 25W 2.1ch Speakers ($28.99 @ Best Buy)
Total: $1327.36
Generated by PCPartPicker 2017-12-17 06:39 EST-0500
I was watching some Twitch Streams then I went to lie down and left the PC running. My brother came in and asked if he could use the PC and I said yeah. He signed in to his User and plugged in a Xbox Controller causing my PC to shut down immediately. After I removed the side panels I took out the Motherboard outside the case and placed in on a table with only the power supply connected to the CPU and 24 pin. I also removed the GPU. I used my screw driver to try to simulate the power button but no post.
I have a power supply tester that my power supply came with but the power supply still spun. I even tried my friend's power supply that I know worked and still no post. I then tried putting my power supply in his build and it posted. I ruled the Power Supply out. I took out all the RAM sticks out and still no post. I tried removing the CMOS Battery and I touched the two pins that reset the CMOS as well but still nothing. The only thing I noticed is that the PWR_LED light flashes green and I remember that it used to remain Solid Green when it worked.
I also need to note that the micro usb was already plugged in on the front usb headers before having the other end plugged in to the Controller. What do you guys think caused this problem and what are some potential fixes.
Total: $1327.36
