Question MicroATX Case, preferably with USB-C port
Feel free to comment or advise.
You didn't specify a budget but here goes.
https://www.newegg.ca/black-fractal-design-meshify-2-mini-micro-atx-tower/p/N82E16811352187
I'd get this and call it a day
or the Fractal Define 7 Mini variant;
https://ca.pcpartpicker.com/products/case/#t=5,7,6,8&sort=price&page=1
or the Fractal Pop Air;
https://www.newegg.ca/white-fractal-design-pop-mini-air-rgb-micro-atx-tower/p/N82E16811352163 and add this;
https://www.amazon.ca/Fractal-Design-Accessory-USB-C-10Gbps/dp/B0B12TL4H5?th=1
to the last case for type-C connectivity.
Reactions: albertkao
Is there a reason for MATX?
Full ATX cases will also hold MATX motherboards.
What will you install inside?
Particularly the cpu cooler.
The case needs to accommodate a cooler.
I am thinking of:
- budget as little as possible
- ASRock B650M-HDV/M.2 motherboard which is microATX size. MicroATX or Full ATX cases are both ok, whichever is cheaper. If the prices are the same, then I prefer MicroATX case, preferably with USB-C port.
- Ryzen 8500G which use little power and comes with a stock cooler
- no dedicated GPU
- no or optional RGB
- no or optional WiFi
- 32GB DDR5 memory
- 1TB SSD
