Micron Has Phase Change Memory in Volume Production
  • Thread starter Thread starter Guest
  • Start date Start date
[citation][nom]A Bad Day[/nom]I wonder how long would it take for AMD and Intel to add support for the PCM?[/citation]
PCM only goes up to a maximum ~400Mbps, is extremely sensitive to temperature, and is rediculously priced if looking for the bulk storage requirements for a PC. Meanwhile we have SSDs for the PC which hit ~500Mbps, are not temperature sensitive, and can be found in 500GB and 1TB sizes, with much larger drives on the horizon (compare to 500MB and 1GB sizes of PCM).
Simply put; the low power requirement makes them excellent for phones and other portable devices which typically use much slower flash memory (20-80MBps) and do not need a lot of space for the OS and applications, but it is relatively useless technology for desktop applications.
Remember that the PCM that Micron is putting into volume production is a VERY immature technology.
I think it would be fair to compare it to the LCD screens used in the original Gameboy in 1989. Imagine how much different and improved our modern day LCDs are in comparison.
They say that flash memory won't scale well in the next 10 years and will require a suitable replacement. PCM may be that replacement, but it's too early to jump on the bandwagon just yet. Modern flash based devices will probably be the smartest way to go for quite a while until the reliability and price of PCM goes down.
[citation][nom]caedenv[/nom]PCM only goes up to a maximum ~400Mbps, is extremely sensitive to temperature, and is rediculously priced if looking for the bulk storage requirements for a PC.[/citation]
I believe you are rather miss informed, PCM chips have been demonstrated at reading at around 300 - 400MB's "megabytes" from a single chip of pcm rather than an array of chips akin to how ssd's get their performance.
in another example a storage system using pcm has also been demonstrated using PCM chips that was capable of reads of up to 1.1GB's "yes gigaBYTES".
here is some literature if you are interested http://www.tgdaily.com/hardware-features/56363-phase-change-memory-device-knocks-ssds-off-their-perch
and ofcourse PCM is expensive, its an experimental technology still.
I understand that this is a low-power module specifically for mobile devices. Intel may need to support it with their Atom mobile chips, but AMD I don't see the need to support this.
[citation][nom]eddieroolz[/nom]I understand that this is a low-power module specifically for mobile devices. Intel may need to support it with their Atom mobile chips, but AMD I don't see the need to support this.[/citation]
Sounds like something to look forward to in a Microsoft Surface 2.
[citation][nom]caedenv[/nom]PCM only goes up to a maximum ~400Mbps, is extremely sensitive to temperature, and is rediculously priced if looking for the bulk storage requirements for a PC. Meanwhile we have SSDs for the PC which hit ~500Mbps, are not temperature sensitive, and can be found in 500GB and 1TB sizes, with much larger drives on the horizon (compare to 500MB and 1GB sizes of PCM).Simply put; the low power requirement makes them excellent for phones and other portable devices which typically use much slower flash memory (20-80MBps) and do not need a lot of space for the OS and applications, but it is relatively useless technology for desktop applications.[/citation]
Not all PCM memory technologies are so temperature sensitive, IBM's PCM memory is among the fastest working memories in the world, the 512Mb and 1Gb sizes are for individual chips, and no single NAND flash chip is 512GB or 1TB. These PCM chips are also undoubtedly very small if they are intended for smart phone usage, so if a company really wanted to, they could probably make a very high capacity SSD out of them.
http://www.pcworld.com/article/234809/ibms_nextgen_memory_is_100_times_faster_than_flash.html
IBM's PCM memory is also supposedly very cheap to manufacture.
Something sounds wrong with that. Are you doing the bits -> bytes conversion correctly? And if IBM's PCM is so great and cheap to produce, why hasn't it replaced flash memory yet in solid state devices? The article you linked also said that this stuff won't be around for a few more years.
[citation][nom]AgentLozen[/nom]Something sounds wrong with that. Are you doing the bits -> bytes conversion correctly? And if IBM's PCM is so great and cheap to produce, why hasn't it replaced flash memory yet in solid state devices? The article you linked also said that this stuff won't be around for a few more years.[/citation]
Nowhere in my comment is a bits to bytes conversion necessary. As for why IBMs memory isn't in heavy production, well, why aren't the many far superior technologies to what we have now in heavy production? Simple. They haven't been invested in enough or maybe they're not commercially ready in some way. Regardless of why, you make it seem like stuff gets sold just because it is superior to what we have now. This is not necessarily true.
Whether or not IBM's PCM memory will be around for a few more years is almost completely irrelevant to this discussion.
