Microphone front panel jack stopped working.
Titration
67
Hello. Yesterday when I was going to play a game with a friend and talking through skype my microphone had stopped working. I called the skype sound test and all you could hear were small clicks and the microphone worked just fine the day before. My case is about 3 weeks old and it's a Corsair Spec-03 and i'm using an MSI motherboard, if you need more hardware info, let me know.
Any help appreciated. :)
You said it was new...did you connect the front panel Audio Header to the MOBO with the AC97 lead or the HD Audio lead? There's a difference depending on what Sound is on the Motherboard. I'll assume it's new too so likely HD Audio
Well, I had the same problem with my old case, but that one didn't work from the beginning and when I got the new case it worked fine until now.
