Question Microphone is not plugged in
Jan 27, 2019
Hello,
I recently buy new monitor(has 3.5mm in it), and since then my mic does not work, but sound does. I tried to reinstall drivers, and i also check the cables, but no fix. So do u have some advise how to fix it? And plugging headphones into monitor is not an option.
p.s. i have win7
010010
Respectable
Jun 29, 2016
614
6
2,365
120
The TV jack won't work for audio input, i think you can use RCA for TVs but i doubt your mic will use that. they don't usually have 3.5m mic input so you will have to plug it in to the PC. If your PC has seperate Mic and Headphone you will need a splitter like that one. Some devices will allow both Mic and audio in one jack but i don't think it's standard.
Jan 27, 2019
I plug my headphones into the speakers, and it worked fine (both sound and mic) when i had my old monitor, but now for some reason only sound work. Mic is apparently not plugged in.
Similar threads
