Microphone Software Problems
7
I have an aplication called voicemeeter on my pc because I want to remove backround noise from my microphone, and the application does that. But any audio in games wont work. I tried setting defaults in games but that didnt help. It seems like its hogging my headphones out audio
I recommend checking your Output audio device located inside Control Panel. Voicemeeter is a new driver, and I believe that after being installed it is set to default. You have to change that to hear your system sounds.
