Microphone sound input low
vedant.naik09
8
Hi..I just bought a new earphone including mic.
I couldn't hear the previous mic properly.The wire broke too so I had to buy a new one.When I record from this mic the sound is very low that I can barely hear it.Boost is full,Recording volume is full but the sound is still low.Works properly in mobile.Noise suppression and Echo cancellation is on.
Any Suggestions?I am running Windows 10
My OS is Windows 10.
Manufacturer:Intel
Speed:3.07 GHz
Generation:8th
Brand:Core i3
Cores:2
OS:Windows 10
Processor:Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz, 3059 Mhz, 2 Core(s), 4 Logical Processor(s)
Make and model of your earphone? You seem to be working with an earphone meant for phones which require a different pole than the desktop platform.
Depending on your earphones, you may require an adapter like this
+ How are you connected to your audio source on your desktop? Via the front/rear panel I/O?
I have Mi Max 2 earphones.And yes I think it is meant for phones.But I had a Motorola Headphones previously and it had a mic attached to its wire.The voice was low too.I will try to attach it to any other pc
