Microphone which wont pick up much keyboard/mouse sound?
Kvistu
Hey There!
Do you guys know any good microphones which won´t pick up that much background /mouse/Keyboard sound? I am currently using the ModMic 4.0 but its just to loud.. every click button press is getting pick up even when somebody is doing something in a different room..
So yea are there any good microphones which wont pick up as much as the Modmic?
tips/software..?
It's a condenser mic, so it will be highly sensitive. You should opt for a dynamic one. The market is scarce with decent attachable mics, which I believe are all condenser, so you probably have to look for a desktop mic. In case you don't know, you'll have two choices: USB and XLR. XLR is considered to be more professional grade, but it can't be connected to a computer directly, so you would need an audio interface or a mixer, maybe also a preamp.
Regarded mics that I know of are Electro-Voice RE320, Heil PR-40, Rode Podcaster, Rode Procaster, and Shure SM7B.
