Mid - Low range cards
darkoverlord123
23
I have a Intel Core 2 Duo 3 GHz, 2GB RAM, Intel DG35EC Motherboard, 300W PSU, Windows Vista Home Premium 64-Bit, and I am looking for a mid-low range card, I am currently looking at the Nvidia GT630 and GT620 and it has to be under 85 USD, any help??
You could consider:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127686 gt640 nets to $50 after mir
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121639 gt630 nets to $78 after mir
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161397 hd6670 nets to $70 after mir
Tom
jemm
The best you can get at that price range is a PowerColor AX7750 1GBK3-H Radeon HD 7750 1GB http://www.newegg.com/Product/Product.aspx?Item=N82E16814131481
It performances like a GeForce GTX 650, but a lot cheaper! ;)
From Tom´s: "The Radeon HD 7750 is the fastest graphics card you can get right now that doesn't require an auxiliary power input; it draws all that it needs from a 16-lane PCIe slot. If you're upgrading an older machine with limited power supply capacity, that's an attractive point to consider." http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-2.html
darkoverlord123
23
The Radeon HD 7750 requires 4GB memory and I only have two and I can't afford the upgrade :(
darkoverlord123
23
darkoverlord123
23
But even if the 630 is 2GB and the 6670 is only 1GB and I still can't afford the 7750 either way
